The JMP Samples/Scripts/SAS Integration folder contains sample scripts. To run the stored process scripts successfully, the stored processes need to be placed on your SAS Metadata Server. The stored processes can be found in the sampleStoredProcesses.spk file, also in this folder.
6.
Enter the full path to sampleStoredProcesses.spk or use the Browse button to navigate to it.
7.
Select All Objects in the Import Options section of the wizard.
8.
Click Next.
9.
Click Next.
11.
Click Next.
13.
Click Next.
After the import completes, you will find a folder named BIP Tree under the folder that you imported the stored processes into. Under BIP Tree is a folder named JMP Samples, and in the JMP Samples folder are two sample stored processes: Shoe Chart and Diameter.
Please note that the paths to the sample stored processes needs to be adjusted in the sample scripts storedProcessHTML.jsl and storedProcessJSL.jsl to match the folder into which you imported the sample stored processes. Otherwise, these scripts will not work correctly.
