Because JMP is supported as both a 32-bit and a 64-bit Windows application, you must install the corresponding 32-bit or 64-bit version of R. For the supported version of R, see the system requirements on the JMP website: https://www.jmp.com/support/system_requirements_jmp.shtml
Create the variable in your system environment variables using the Control Panel, select Start > Control Panel > System > Advanced system settings.
Click Environment Variables.
Type R_HOME for the Variable name.
Create the variable using the JSL Set Environment Variable() function:
Look up the environment variable R_HOME.
If the environment variable R_HOME does not exist, look up the InstallPath value in the Windows registry under the following key:
For 32-bit R running on a 64-bit machine, the InstallPath value is in the following key:
If the InstallPath value exists, load R from the specified directory.
If the InstallPath value does not exist, an error message states that R could not be found.
R Init( );
R Submit( "
R Term( );
