JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Extending JMP
• Working with Microsoft Excel
上一个
下一个
You can script the Profiler interface to Microsoft Excel, although not the Transfer to JMP interface. The basic syntax is as follows:
excel_obj = Excel Profiler(
Workbook( "excel_workbook_path" ),
Model( "name_of_model" )
The
Model
argument is optional. If you supply only the workbook, you are prompted to select the model. You do not need to specify the worksheet, because the model is found no matter where it is located.
Once you have an Microsoft Excel Profiler object, you can send the following messages to run the JMP prediction profiler using the Microsoft Excel model. For example:
excel_obj <<Prediction Profiler( 1 );
