The term live data feed describes the way an external data source sends information via a physical or a logical communication link to another device. You can connect JMP to a live data feed through the serial port of your Windows computer to read a stream of incoming data in real time. Remember the following:
Once you obtain the numbers for your device, enter them into the Open Datafeed() command in the script below. (The 4800, even, 2, and 7 in the script below are examples, so replace them with your information). Then connect the data feed to your computer and open and run the script:
Show( line );
len = Length( line );
Show( len );
If( Length( line ) >= 1,
Show( "Hi" );
Show( line );
field = Substr( line, 5, 8 );
Show( field );
x = Num( field );
Show( x );
If( !Is Missing( x ),
dt << Add Row( {:Column1 = x} );
Show( x );
feed = Open Datafeed(
feed << Set Script( streamScript );
feed << Connect;
To ensure harmony between the communications settings for JMP and the instrument reading data from an external source, select File > Preferences > Communications. Refer to the documentation for your instrument to find the appropriate settings.
