By group arguments are supported for these functions: ColMean(), ColStdDev(), ColNumber(), ColNMissing(), ColMinimum(), ColMaximum().
Any number of BY arguments can be specified, and you can use expressions for the BY arguments. BY arguments must be used in a column formula, or in the context of ForEachRow(). The first argument can also be a general numeric expression.
Formula( Col Minimum( :height, :sex, :age ) )
dt << Tabulate(
Show Control Panel( 0 ),
