You can also encrypt a script that is saved to a data table using the JSL Encrypted() or Include( Char to Blob() ) functions.
JSL Encrypted() is more straightforward, because it involves one function. You can include comments inside the encrypted script.
Include( Char to Blob() ) lets you include comments, but not inside the script.
If you entered only a decrypt password, click Yes to confirm that you do not want to assign a run password.
10.
图 8.5 Example of an Encrypted Data Table Script
