JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Three-Dimensional Scenes
Setting the Viewing Space
• Setting up an Orthographic Scene
上一个
下一个
Orthographic scenes are specified in ways similar to perspective scenes. Issue the command
Ortho(
left
right
bottom
top
near
far
which specifies the four corners of the near plane, the distance to the near plane, and the distance to the far plane.
If you are dealing with a simple 2-D environment, you can set up a two-dimensional orthographic scene with the command
Ortho2D (
left
right
bottom
top
which specifies the corners of the two-dimensional view.
