JMP displays numbers as currency using the Format() function, which uses the following syntax:
x is a column or a number
"currency code" is an International Standards Organization (ISO) 4217 code
decimal is the number of decimal places
To illustrate the Format function:
提示:If you change the region when JMP is open, restart JMP for the Use Locale setting to work properly.
Currencies Supported in JMP lists the currencies supported in JMP.
