Munger works many different ways, depending on what you specify for its arguments:
If you specify a string as the find and specify no replace string, Munger returns the position (after offset) of the first occurrence find string.
If you specify a positive integer as the length and specify no replace string, Munger returns the characters from offset to offset + length.
If you specify a string as the find and specify a replace string, Munger replaces the first occurrence after offset of text with replace.
If you specify a positive integer as the length and specify a replace string, Munger replaces the characters from offset to offset + length with replace.
If you specify a positive integer as the length, and offset + length exceeds the length of text, Munger either returns text from offset to the end or replaces that portion of text with the replace string, if it exists.
If you specify zero as the length and specify a replace string, the string is inserted before the offset position.
If you specify a negative integer as the length value and specify no replace string, Munger returns all characters from the offset to the end of the string.
If you specify a negative integer for length and specify a replace string, Munger replaces all characters from the offset to the end with the replace string.
