Converts an expression to a version that is more suitable for SAS DATA step. The code must be wrapped in a PROC DS2 call. Use Expr(...) for literal expressions. Use NameExpr(name) for expressions stored in a variable. Otherwise, the expression returns the expression to convert.
1 if connection is successful, 0 if not.
If specified, Meta Connect returns the status of the I want to connect to a SAS Metadata Server option in the SAS Integration page of JMP Preferences. If that box is checked, Meta Connect returns 1; if not, 0.
If machine and port are specified rather than a profile name, and ProfileLookup is specified, an attempt is made to find a metadata server connection profile with a machine name and port matching those provided. If one is found, other connection information (such as authentication domain, user name, and password) is obtained from that profile.
Takes one of the keywords Always (always prompt before attempting to connect), Never (never prompt, just fail), or IfNeeded (the default; prompt if connection with the given arguments fails).
Attempts to change the SAS version preference to the specified value before making the metadata server connection. If the SAS version is already locked to a different version than the one specified, the SASVersion argument will fail. By default, if the SAS version cannot be set, JMP will try the metadata server connection. However, if you include Strict as the second argument, the inability to change the SAS version will be treated as an error, and JSL processing will stop. If you do not include Strict, the SAS version argument is treated as a hint and will set the version preference if it can. JMP will still try to connect if the version cannot be set. The order you put these arguments in can make a difference. The attempt to change the SAS Version is made immediately when that argument is encountered. That can affect the validity of other arguments, particularly for MetaConnect. Valid values for SASVersion are “9.1.3”, “9.2”, “9.3”, and “9.4”. Note: Using the SASVersion argument has the same effect as changing the SAS Server Version on the SAS Integration Preferences page.
1 if profile was successfully created, otherwise 0.
The port number (n) that the SAS Metadata Server is listening for connections on.
If name matches a profile that already exists, Replace must be specified for the existing profile to be replaced by the one provided. The default value is False (0).
1 if a connection exists; 0 otherwise.
1 if setting the repository was successful, 0 otherwise.
Optional: quoted string that can contain a physical machine name or the name of a metadata-defined (logical) server. In the first case, the port must be provided. In the second case, a port must not be provided. If neither name nor port are included, and JMP is running on Windows, a connection to SAS on the local machine (via COM) is attempted, and all named arguments are ignored.
Optional: quoted string or integer. If name is a physical machine name, this is the port on that machine to connect to. If name is a metadata-defined (logical) server, port must not be included.
A Boolean. The default value is True. If True, and a successful SAS server connection is made, this connection replaces the active SAS connection that becomes the target of other global SAS JSL function calls. If False, the global SAS connection is not changed, and the returned SASServer scriptable object should be used to send messages to this server connection.
A Boolean. The default value is False. If True, other arguments (except ReplaceGlobalConnection) are ignored and the SAS Server Connection window appears. This provides the JSL programmer a way to open the SAS Connect window.
A keyword. Always means always prompt before attempting to connect. Never means never prompt even if the connection attempt fails (just fail and send an error message to the log), and IfNeeded (the default value) means prompt if the attempt to connect with the given arguments fails (or is not possible with the information given).
Attempts to change the SAS version preference to the specified value before making the metadata server connection. If the SAS version is already locked to a different version than the one specified, the SASVersion argument will fail. By default, if the SAS version cannot be set, the metadata server connection will still be tried. However, if you include Strict as the second argument, the inability to change the SAS version will be treated as an error and JSL processing will stop. If you do not include Strict, the SAS version argument is treated as a hint and will set the version preference if it can, but if it cannot it will still try to connect. The order you put these arguments in can make a difference. The attempt to
1 if the data table was exported successfully; 0 otherwise.
A Boolean. If true and the JMP data table originally came from SAS, the original SAS column names are used in the exported SAS data set. The default value is False.
A Boolean. If true and the JMP data table originally came from SAS, the original SAS formats and informats are applied to the columns in the exported SAS data set. The default value is True.
Quoted string that contains the encoding used in the file (for example, "utf-8"). The server must support the specified encoding.
Optional, Boolean. If True, then for any libraries that have friendly names (metadata-defined libraries), the friendly name is returned rather than the 8-character libref.
If True, the labels from the SAS data set become the column names in the resulting JMP table. If False, the variable names from the SAS data set become the column names in the JMP table. The default value is False.
Simple | Unrestricted: If Simple is specified, sampling is performed without replacement. If Unrestricted is specified, sampling is performed with replacement. These two options are mutually exclusive and only one can be specified.
SampleSize(int) | N(int): Total number of rows for the sample, or number of rows per strata level for stratified sampling
SampleRate(number) | Rate(number) | Percent(number): Specifies the sampling rate. For stratified sampling, the rate is applied to each strata level. Note that the supplied value is assumed to be a percentage, so SampleRate(3.5) means a 3.5% sampling rate.
Strata({col1, col2, ...}) | Strata(col1, col2, ...): Perform stratified random sampling using the column names supplied as Strata variables.
NMin(int): Minimum number of rows (either overall or per strata level for stratified sampling) to return. Only applies to rate-based sampling.
NMax(int): Maximum number of rows (either overall or per strata level for stratified sampling) to return. Only applies to rate-based sampling.
Seed(int): Number to use as the seed for sampling. Useful for replicating the same sample. By default, the seed is a random number based on time of day. See PROC SURVEYSELECT documentation for more information.
OutputHits(0|1): Boolean; the default value is false. When doing Unrestricted sampling, if the same row of the input data set is selected more than once, by default that row still appears only once in the resulting JMP data table, with the NumberHits column indicating the number of times that the row was selected. Setting OutputHits to true causes an input row that is selected multiple times to appear multiple times in the resulting JMP data table.
SelectAll(0|1): Boolean, the default value is true. If SelectAll is true, PROC SURVEYSELECT selects all stratum rows whenever the stratum sample size exceeds the total number of rows in the stratum. If SelectAll is false and PROC SURVEYSELECT finds a case where the stratum sample size exceeds the total number of rows in a given stratum, an error results and sampling fails. SelectAll only applies to Simple random sampling.
If True, an SQL table variable is created in the resulting JMP table that shows the SQL that was submitted to SAS to obtain the data. If False, the SQL table variable is not created. The default value is True. If an SQL table variable is created and the data set required a read password, the password is masked.
The default value is true. If True, the labels from the SAS data set become the column names in the resulting JMP table. If False, the variable names from the SAS data set become the column names in the JMP table.
The default value is true. If True, an SQL table variable is created in the resulting JMP table that shows the SQL that was submitted to SAS to obtain the data. If False, the SQL table variable is not created. If an SQL table variable is created and the data set required a read password, the password is masked.
1 if an active global SAS connection exists, 0 otherwise.
A Boolean. If True (1), the submit occurs asynchronously (in the background). Use the Get Submit Status() message on the SAS Server Scriptable Object to determine the status of the submit. The default value is False (0).
A Boolean. When SAS data sets generated by submitted SAS code are imported into JMP after the submit completes (see Open Output Datasets), the value of ConvertCustomFormats determines whether an attempt is made to convert any custom formats found on columns in the SAS data to JMP value labels. The default value is True (1).
A Boolean. If no arguments are supplied, the SAS Log is retrieved and displayed in the location indicated in SAS Integration Preferences. The first argument to GetSASLog can be either a Boolean value or the keyword OnError. If a Boolean value is supplied, true means display the SAS Log, and false means not to display it. OnError instructs JMP to only show the SAS Log if an error occurred in the submit. The second argument to GetSASLog tells JMP where to display the SAS Log. If JMPLog is specified, the SAS Log is appended to the JMP Log. If Window is specified, the SAS Log is opened in a separate window.
JMP includes the QUIT statement in the generated wrapper code. Interactive PROCs work even if JMP is generating the ODS wrapper. On every SUBMIT, specify the argument that is part of an interactive sequence. Otherwise, QUIT will be generated in both the prologue-generated and epilogue-generated code.
A Boolean. If True, the SAS Output window containing the listing output from the submission does not appear. The default value is False.
If true, ODS statistical graphics are generated for the submitted SAS code. Setting ODSGraphics to true causes ODS to also be set to true. The default value is determined in Preferences.
A quoted string that specifies the ODS Style to use when generating ODS results. String must be a valid SAS Style. The default value is determined in Preferences.
A quoted string that specifies a local CSS style sheet to use when formatting generated ODS results. Path must be a path to a CSS file valid for the client machine (the machine running JMP). The default value is determined in Preferences.
JMP detects when submitted SAS code creates new SAS data sets. OpenOutputDatasets (which can be abbreviated OutData) determines what, if anything, is done with those data sets with the SAS Submit completes. If All is specified, all data sets generated by the SAS code are imported into JMP when the SAS Submit completes. If None is specified, none of the generated data sets are imported. If there are specific data sets known to be generated by the submitted SAS code that you want to be imported into JMP when the SAS submit completes, you can alternative provide their names, and only the requested data sets are imported. The default value is determined in Preferences.
