JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
JSL Messages
• SAS Integration Messages
上一个
下一个
Metadata Server Objects
metaserver<<Disconnect()
Function
Disconnects the metadata server.
Returns
Void.
metaserver<<Get Display Name()
Function
Gets the display name of the metadata server.
Returns
A string.
metaserver<<Get Host Name()
Function
Gets the host (machine) name of the metadata server.
Returns
A string.
metaserver<<Get Port()
Function
Gets the port used for the metadata server connection.
Returns
An integer.
metaserver<<Get User Identity()
Function
Gets the identify of the connected user as defined in metadata.
Returns
A string.
metaserver<<Get User Name()
Function
Gets the user name (login ID) that was used for the metadata server connection.
Returns
A string.
