Description
Disconnects the metadata server.
Returns
Void.
Description
Gets the display name of the metadata server.
Returns
A string.
Description
Gets the host (machine) name of the metadata server.
Returns
A string.
Description
Gets the port used for the metadata server connection.
Returns
An integer.
Description
Gets the identify of the connected user as defined in metadata.
Returns
A string.
Description
Gets the user name (login ID) that was used for the metadata server connection.
Returns
A string.
