JSL Syntax Reference > JSL Messages > Display Boxes > Number Col Edit Boxes
发布日期: 08/07/2020
Number Col Edit Box<<Set Format(<width>, <decimal places>, <"Use Thousands Separator">|<other options>)
Description
Sets the column format.
Arguments
A number of other formats can be set on number col edit boxes. See Number Col Box<<Set Format(<width>|<width, decimal places>, <"Use Thousands Separator">) for more information about the syntax. Numeric Formats in Using JMP also describes the arguments.
Number Col Edit Box<<Remove Element(x position, y position, i)
Removes an element from the column at the specified position.
