Inclusion/Exclusion Criteria Not Met
The Inclusion/Exclusion Criteria Not Met field is an optional parameter that enables you to filter rows from the IE data set to choose the appropriate records to subset to failed inclusion or exclusion criteria of interest. Risk indicators are calculated using this subset of inclusion or exclusion criteria only.
To specify a Disposition filter:
8 | Click to open the Where Clause Builder to construct the desired filter. |
8 | Click to clear the filter. |
