Studies
Introduction
A study is a collection of input data folders, settings, and an output folder. Specifically, a study consists of a Study Name associated with one or more data set folders (at least one SDTM Folder or ADaM Folder must be specified) and zero or more settings, along with a unique Output Folder.
Various metadata files are created when a study is added to JMP Clinical and the reports use these metadata files for their analyses. These files are stored in three subfolders within the <CONFIGURATION ROOT>/Studies/<STUDY NAME> root folder: Data, DataDerivedMetadata, and Metadata. Additionally, system and user notes are stored in files within <CONFIGURATION ROOT>/Notes/<STUDY NAME>.
See Adding and Manipulating Studies for more information.
All study additions and manipulations are done on the Studies tab shown below:
Note: For instructions on how to add the Nicardipine example study that ships with JMP Clinical, see Add Study...
Available Studies
All of the registered studies available to you are listed here. Studies can be sorted by various criteria in ascending or descending order.
8 Click to select a study. Use -click to select multiple studies.
Note: For a study to be shown here you must have read-access to both the original study data folders and a valid study metadata object file.
Study Information
Information about the selected study is shown in the panel on the right side of the window. This includes the date the study was created, when it last updated and when it was last accessed. Additionally, the location of the study data within your file structure is shown along with a list of the domains that make up your study data. In the Nicardipine study shown above, there are 3 events domains (AE, DS, and MH), 3 findings domains (EG, LB, and VS) 2 interventions domains (CM and EX), and three special domains (ADSL, DM, and SV).
JMP Clinical can read data from individual domains as well as multiple domains where the study data is split among multiple domains.
Study Operations
Use these buttons to add, manipulate, or delete registered studies.
Add Study: Click to use Add Study...
Combine Studies: Click to combine two studies using Combine Studies . Note: This option remains unavailable unless two studies are selected.
Refresh Study Metadata: Click to update the metadata file for the selected study.
Rename a Study: Click to rename a study.
Snapshot History: Click to use Snapshot History to generate a summary report of the snapshot history for the currently selected study
Update Study with New Snapshot: Click to update the selected study with a new snapshot. See Update Study with New Snapshot for more information. Note: This option is available only if the option was checked when you added the Study.
Update Site Details for Risk Based Monitoring: Click to generate a data set listing the site identifier and country of each study site. Desired additional site-specific descriptive information can be manually added to this data set .
Set Study Preferences: Click to globally set custom study-level attributes, subject-level preferences, analysis preferences for each CDISC class of reports, preferences for calculating study days, as well as preferences for advanced operations. See Set Study Preferences for more information.
Set Value Order and Color in Studies: Click to use Set Value Order and Color in Studies to specify the order and color of values within variable specific plots, such as histograms, and tables, as well as the order of value-comparison plots and tables within output.
Delete Studies: Click to delete the selected study. After a study is deleted, its notes and reviews folders remain where they were. The log and result files are moved to \ProcessResults\ directory and the study folder under studies is deleted. Note: If the KeepDeletedStudiesNotesAndReviews system preference is activated on Manage Configurations (this preference is Off by default), all notes and reviews are deleted as well.
Refreshing Studies
Occasionally, you may need to update your studies. This may be after you have updated the study data or when you have updated JMP Clinical to a newer version. Follow the instructions below, depending on what you have done.
After updating the study data:
To refresh an updated study
8 After updating the study data, open JMP Clinical and click on the Studies tab.
8 Click on the study to be refreshed.
8 Click to refresh the study.
After updating JMP Clinical
8 Install/Update JMP Clinical.
8 Open JMP Clinical and open the Studies tab
8 Select a study and click to refresh that study. Repeat for all of the studies.
8 Select one of studies as the Current study.
8 Click on the Settings tab and then click to open the Configuring JMP Clinical.
8 Navigate to the Report Management section and click .
8 Close the Configuring JMP Clinical. and then close JMP Clinical.
8 Reopen JMP Clinical and proceed as normal.
