Adverse Events
The Adverse Events field is an optional parameter that enables you to filter rows from the AE data set to choose the appropriate records to subset to adverse events of interest. Risk indicators are calculated using this subset of adverse events only.
This filters uses JMP WHERE clauses to Select Rows that meet the specified criteria. To use this filter, you must enter the JSL (JMP Scripting Language) expressions that constitute the WHERE clause in the appropriate text box for specific filtering of AEs. Note: This is an advanced concept that not only requires some basic knowledge of the JSL where clause syntax (similar to, but different from, SQL), but also an understanding of the exact variables in the tables in the study.
To specify an Adverse Events filter:
8 | Click ![]() |
8 | Click ![]() |
