Plot findings measurements as:
Select the type of findings measurement values to plot.
Available options are listed in the following table:
Option
Description
Observed result
Plots observed values of the xxSTRESN variable at or within time points or specified time periods.
Change from baseline
Plots the change from the findings baseline measurements (determined by the xxBLFL variable and/or a user-defined Baseline Time Window) and is calculated as xxSTRESN - Baseline.
Percent change from baseline
Plots 100*((xxSTRESN - Baseline)/Baseline) across trial time points.
Percent of baseline
Plots 100*(xxSTRESN/Baseline).
To Specify the Measurement Type:
8 Click within the appropriate radio button.
