Seed Number
Use this option to specify a value used to generate random samples from specified distributions.
This option is useful for result comparisons by controlling the seed from which the samples are randomly chosen.
You must enter an integer greater than or equal to one (1).
To Change the Seed:
8 | Either highlight the existing random number seed and enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
