To launch Graph Builder, open your data table and then select Graph > Graph Builder. The Variables list contains the columns in your data table, which you can drag into zones.
Tip: For descriptions of the column options in the Variables red triangle menu, see Columns Panel in the Using JMP book.
To recreate and modify the graph in Graph Builder Window for Big Class.jmp, follow these steps:
The graph in Graph Builder Window for Big Class.jmp appears. The relationship between height and weight for each value of age is shown using color in a single graph.
6.
