The Across Groups analysis corresponds to a simple repeated measures analysis. (You can get the same test results using the Manova personality of the Fit Model platform.)
Two F-tests determine whether the across-groups values are different:
Mean Difference tests that the change across the pair of responses is different in different groups.
Mean Mean tests that the average response for a subject is different in different groups
