Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Matched Pairs Analysis
The Matched Pairs Report
• Difference Plot and Report
The Difference plot shows differences by means. In the Difference plot, note the following:
The mean difference is shown as the horizontal line, with the 95% confidence interval above and below shown as dotted lines. If the confidence region includes zero, then the means are not significantly different at the 0.05 level. In this example the difference is significant.
If you add a reference frame, the mean of pairs is shown by the vertical line. For details about a reference frame, see
Matched Pairs Platform Options
The Difference report shows the mean of each response, the difference of the means, and a confidence interval for the difference. The Difference report also shows the results of the paired t-test.
Help created on 9/19/2017
