Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Prospective Sample Size and Power
One-Sample and Two-Sample Proportions
• Actual Test Size
Actual Test Size
The results also show the Actual Test Size. This is the actual Type I error rate for a given situation. Since the binomial distribution is discrete, the actual test size can differ significantly from the stated Alpha level for small samples or proportions near 0 or 1.
Help created on 9/19/2017
