The Sample Size windows and computations to test sample sizes and power for proportions are similar to those for testing means. You enter a true Proportion and choose an Alpha level. Then, for the one-sample proportion case, enter the Sample Size and Null Proportion to obtain the Power. Or, enter the Power and Null Proportion to obtain the Sample Size. Similarly, to obtain a value for Null Proportion, enter values for Sample Size and Power. For the two-sample proportion case, either the two sample sizes or the desired Power must be entered. (See Power and Sample Window for One-Sample Proportions and Difference Between Two Proportions for a Two-Sided Test.)
