Opens the script in the JSL Debugger to troubleshoot errors. See Debug or Profile Scripts in Scripting Tools for more information.
Opens a sample application from the JMP Samples/Apps folder. These samples show you how to set up common applications, and you can modify them as you wish. Sample Applications Installed with JMP describes the samples.
Lets you save the application to a data table, journal, script window, or add-in. See Options for Saving Applications for details.
Creates two Bubble Plots. Each plot has its own data filter and Tabulate report. See this application for an example of the Data Filter Context Box function.
A modified version of Instant App.jmpappsource. Options for selecting the principal components report, changing the marker size, and showing means are included.
