You can use Add-In Builder with Application Builder. First, use Application Builder to write complex scripts that create new platforms and interact with users and JMP. Then, use Add-In Builder to easily distribute your complex scripts so that any JMP user can access them without having to open and run scripts. See Compile Add-Ins with the JMP Add-In Builder
