Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Statistical Details
The Usual Assumptions
• Assumed Model
Assumed Model
Most statistics are based on the assumption that the model is correct. To the extent that your model may not be correct, you must attenuate your credibility in the statistical reports that result from the model.
Help created on 9/19/2017
