Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Statistical Details
• The Usual Assumptions
Before you put your faith in statistics, reassure yourself that you know both the value and the limitations of the techniques you use. Statistical methods are just tools—they cannot guard you from incorrect science (invalid statistical assumptions) or bad data.
Help created on 9/19/2017
