Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
Formula Editor
Edit Formulas
• Click and Drag
Click and Drag
You can drag any part of a formula that can be selected to any other location that can be selected.
To click and drag in a formula, follow these steps:
Place the arrow cursor inside an expression.
Click the expression. It is highlighted and the cursor changes to a hand cursor.
Drag across the formula. Destination expressions are highlighted.
Drag the selected expression to the new desired location. The selected expression is copied to the new location, where it replaces the existing expression.
Help created on 9/19/2017
