Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Scripting Guide
Display Trees
Navigate JMP Reports
• Compatibility Warning
JMP platforms are generally stable from release to release. However, sometimes there are compelling reasons to change the structure of reports in major releases. When this happens, old scripts can fail due to the new structure. You need to update the old scripts. It is wise to be resourceful to code scripts in a way to minimize dependencies on the structure.
Help created on 9/19/2017
