The most common control charts are available in the Control Chart Builder and in the Control Chart platform. Use the Control Chart Builder as your first choice to easily and quickly generate charts. JMP automatically chooses the appropriate chart type based on the data. Variable Charts Without Grouping (X) Variable or Nonsummarized Data through Rare Event Charts summarize the different control chart types.
