To copy all text (no graphs) from the active report window as unformatted text, select Edit > Copy As Text. On the Macintosh, select Edit > Copy As Text.
To copy anything other than a graph, right-click and select Edit > Copy Picture. For example, to copy a report, right-click on the bar containing the report title and select the option.
