Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
• Save and Share Data
Save and Share Data
Get Your Data Out of JMP
This chapter covers the following topics:
Save data tables as text files, SAS data sets, Excel files, and other formats
Save reports as interactive HTML, Adobe Flash files, and PowerPoint
Email reports and data tables
Save analyses as scripts
Create JMP journals or projects
Save log windows
The method that you choose depends on how you want to interact with your analyses in the future:
If you want to interactively present your data, you might choose to create a JMP journal.
If you want to send data tables, linked reports, and other items to someone, you might choose to create a JMP project.
If you want to continue to explore a report later, you might choose to create a JMP report.
If you want to send a report to a non JMP user, you might convert the report to interactive HTML.
Contents
Save and Share Data Tables
Save as a Microsoft Excel File
Save as a CSV File
Save as a Text File
Save as a SAS Transport File
Save as a SAS Data Set
Save Data Tables to a Database
Replace a Database with a Data Table
Email a Data Table
Save and Share Reports
Email a Report
Save the Report as Interactive HTML
Create a Web Report
Save as PowerPoint
Save as Flash
Setting the Graphic DPI
Save Your Analysis as a Script
Save Using the Layout Command
Save Parts of a Report in a Graphic Format
Print Reports
Copy and Paste Reports
JMP Journals
Create a New Journal
Prevent Modifications
Append Reports to a Journal
Add and Edit Outline Levels
Control the Display of Outline Levels
Add a Graph or Graphic
Customize Journal Items
Save the Journal in Another Format
Print a Journal
Delete Items from a Journal
Example of Making a Journal for a Presentation
Save JMP Sessions
Save Sessions upon Exiting
Save Sessions Manually
JMP Projects (Windows Only)
Create a JMP Project
Save a JMP Project
Close a JMP Project
Open a JMP Project
Add Items to a JMP Project
Customize the Project
Fix Broken Links
Save a Log Window
Help created on 9/19/2017
