To create an empty journal, select File > New > Journal. Or, from the JMP Starter window, select New Journal.
To create a journal from an entire report or data table, select Edit > Journal.
To create a journal from most graphs, right-click on the graphic, and then select Edit > Journal. (Not available for surface plots and 3-D scatterplots.)
Write a JSL script to create a new journal. See Create Journals and Layouts in the Scripting Guide for more information.
