Click Continue.
From the ALT Plan red triangle menu, select ALT Optimality Criterion > Make Probability I-Optimal Design.
This tells JMP to use the Probability optimality criterion when creating the design in the next step. For details about this criterion, see Make Probability I-Optimal Design.
Click Make Design.
