Select Help > Sample Data Library and open Design Experiment/Borehole Factors.jmp
Select DOE > Special Purpose > Space Filling Design
Factors Panel with Factor Values Loaded for Borehole Example
Note: The logarithm of r and rw are used as factors.
Click Continue.
6.
Click Sphere Packing to produce the design.
7.
Click Make Table to make a table showing the design settings for the experiment.
8.
(Optional) To see a completed data table for this example, select Help > Sample Data Library and open Design Experiment/ Borehole Sphere Packing.jmp.
Help created on 9/19/2017
