Select DOE > Special Purpose > Space Filling Design.
Alter the factor level values, if necessary. For example, Space-Filling Dialog for Two Factors shows the two existing factors, X1 and X2, with values that range from 0 to 1 (instead of the default –1 to 1).
Click Continue.
Space-Filling Design Dialog
6.
Click Sphere Packing.
JMP creates the design and displays the design runs and the design diagnostics. Sphere-Packing Design Diagnostics shows the Design Diagnostics panel with 0.518 as the Minimum Distance. Your results might differ slightly from the ones below, but the minimum distance is the same.
7.
Click Make Table. Use this table to complete the visualization example, described next.
Help created on 9/19/2017
