The factors and their settings are given in the data table Extraction Factors.jmp. You create a definitive screening design to investigate.
Select DOE > Definitive Screening > Definitive Screening Design.
Double-click Y under Response Name and type Yield.
Open the Extraction Factors.jmp sample data table, located in the Design Experiment folder.
Responses and Factors for Extraction Design
Click Continue.
6.
Click Make Design.
Design Outline
7.
Open the Design Evaluation > Color Map on Correlations outline.
Color Map on Correlations for Extraction Design
8.
Click Make Table to obtain the data table shown in Definitive Screening Design for Extraction Process.
Help created on 9/19/2017
