Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Profilers
Surface Plot
Surface Plot Platform Options
• Dependent Variables Options
The Dependent Variables red triangle menu provides the following options:
Formula
Shows or hides the Formula column in the Dependent Variables controls.
Surface
Shows or hides the Surface column in the Dependent Variables controls.
Points
Shows or hides the Point Response Column column in the Dependent Variables controls.
Response Grid
Shows or hides the Grid controls.
Help created on 9/19/2017
