If you have selected the Sheet, points option in the Appearance Controls, you can right-click on the sheet inside the plot and select Sheet Properties to reveal a window that enables you to change the sheet properties. If you are plotting an Isosurface, right-click the surface and select Surface Properties to reveal a similar window. The Sheet Properties and Surface Properties windows enable you to modify the appearance of the surface plot, including the surface color, opacity, and contours. You can also show or hide a mesh that appears on the surface plot.
Sheet Properties Window
Note: The equivalent JSL command for this option is Clip Sheet( Boolean ). You can send this message to a particular response column by appending the number of the response column. For example, Clip Sheet2( 1 ) limits the range of the plot to the range of the data of the second response column. See the Scripting Index in the JMP Help menu for an example.
Help created on 9/19/2017
