Saves the histograms as .swf files that are Adobe Flash player compatible. Use these files in presentations and in Web pages. An HTML page is also saved that shows you the correct code for using the resulting .swf file.
See Local Data Filter, Redo Menus, and Save Script Menusin the Using JMP book for more information about the following options:
