Note: The statistics in this report are based on ranges in the following instances: if you selected EMP as the MSA Method and Range as the Chart Dispersion Type, and you have a one factor or a two factor, balanced, crossed model. Otherwise, the statistics in this report are based on variances.
the median error for a single measurement. Indicates the resolution quality of your measurement and helps you decide how many digits to use when recording measurements. For more information, see Effective Resolution.
Intraclass Correlation (no bias) does not take bias or interaction factors into account when calculating the results.
Intraclass Correlation (with bias) takes the bias factors (such as operator, instrument, and so on) into account when calculating the results.
Intraclass Correlation (with bias and interaction) takes the bias and interaction factors into account when calculating the results. This calculation appears only if the model is crossed and uses standard deviation instead of range.
Tip: To prevent the legend from appearing, deselect Show Monitor Classification Legend in the EMP Measurement Systems Analysis platform preferences.
