Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Measurement Systems Analysis
Measurement Systems Analysis Platform Options
• Effective Resolution
The Effective Resolution report helps you determine how well your measurement increments are working. You might find that you need to add or drop digits when recording your measurements, or your current increments might be effective as is. Note the following:
The Probable Error calculates the median error of a measurement.
The Current Measurement Increment reflects how many digits you are currently rounding to and is taken from the data as the nearest power of ten. This number is compared to the Smallest Effective Increment, Lower Bound Increment, and Largest Effective Increment. Based on that comparison, a recommendation is made.
Large measurement increments have less uncertainty in the last digit, but large median errors. Small measurement increments have small median errors, but more uncertainty in the last digit.
Help created on 9/19/2017
