Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Capability Analysis
• Entering Specification Limits
The lower specification limit (LSL), upper specification limit (USL), and target define the lower bound, upper bound, and target value for a quality process.
There are several ways to enter spec limits:
Enter limits in the Spec Limits window after selecting columns in the launch window. See
Spec Limits Window
Import limits from a JMP data table (known as a Limits Table). See
Limits Data Table
Enter limits as Spec Limits column properties in the data table. See
Spec Limits Column Property
Only one spec limit is required for a selected column. If only the upper spec limit (USL) is specified, the box plot is colored blue. If only the lower spec limit (LSL) is specified, the box plot is colored red.
Help created on 9/19/2017
