The Semiconductor Capability.jmp sample data table contains 128 columns of process measurements. Each column contains 1,455 measurements. You are interested in which of the processes are unstable. Also, each column contains a Spec Limits column property. If a process is stable, it is appropriate to calculate its process capability. You proceed to assess both stability and capability for this data table.
Select Help > Sample Data Library and open Semiconductor Capability.jmp.
Select Analyze > Screening > Process Screening.
Select the Processes column group and click Process Variables.
Partial View of Initial Report
Quick Graphs for Highest Alarm Rate Processes
You decide to take a closer look at IVP8 (row 3, column 1 in the Graphs of Selected Items).
Control Chart Builder Report for PNP9
A Control Chart Builder report appears. Because IVP8 has a Spec Limits column property, the report also includes a capability analysis.
Help created on 9/19/2017
