Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Process Screening
• Process Screening Platform Overview
The Process Screening platform facilitates the task of assessing data from a large number of processes for stability and capability. The results are largely based on control chart calculations to determine when a process is out of control. The Process Screening platform enables you to:
Specify a constant subgroup size or use a variable containing subgroup identifiers for control chart calculations using subgroups.
Use variables that identify different processes as grouping variables. An analysis is provided for each process variable for each combination of values of the grouping variables.
Use medians to make your centerline and sigma calculations robust to outliers.
Obtain information about the location of large shifts in the mean of your processes.
You can customize the Summary report to show the control chart tests that you want, including tests for changes in process mean and spread. The report also provides capability information when you supply specification limits. The Process Performance Graph gives you a visual representation of the performance of your processes in terms of stability and capability. The Shift Graph shows locations of upshifts and downshifts.
Process Screening makes it easy to select specific processes for further analysis. The platform provides small run charts for these processes - the size of the plots makes it easy for you to view a substantial number at a time. You can also link to Control Chart Builder and the Process Capability platform for analyses of select processes.
You can save data tables containing results in various forms, either for your entire set of processes or only for select processes.
Help created on 9/19/2017
