Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Taguchi Designs
Taguchi Design Window
• Factors
Factors
Add factors in the Factors outline.
Signal
Specify one or more 2- or 3-level signal factors. Signal factors are system control inputs. These are factors that you can control in production.
Noise
Specify one or more noise factors. Noise factors are variables that are difficult or expensive to control in production. However, you must be able to control noise factors during the experiment.
Remove
Removes the selected factors.
The steps for specifying factors are given in
Entering Factors
Click to add a signal, then select a signal type:
2 Level
, or
3 Level
Or click to add a noise.
Double-click to edit the factor name.
To change the value of a signal or noise, click and then type the new value.
Entering Factors
When you finish adding factors, click
Continue
Help created on 9/19/2017
