The Goal Plot shows, for each variable, the spec-normalized mean shift on the x-axis, and the spec-normalized standard deviation on the y-axis. It is useful for getting a quick, summary view of how the variables are conforming to specification limits. Hold your cursor over each point to view the variable name. The Goal Plot red triangle menu has the following commands:
Goal Plot shows the Goal Plot for the entire data set for the Semiconductor Capability.jmp sample data table after selecting Shade CPK Levels from the Goal Plot red triangle menu.
Goal Plot
Mean Shift Normalized to Spec = (Mean(Col[i]) - Target) / (USL[i] - LSL[i])
Help created on 9/19/2017
