Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Essential Graphing
Graph Builder
Right-Click Menus
• Graph Options
Graph Options
Right-clicking in a graph shows the following:
Element types that appear in the plot (such as Points, Line, and so on). Sub-menus provide options that are specific to each element type, and general options. Alternatively, you can change element-specific options in each element’s properties panel, below the Variables panel.
The Add option, where you can select other elements to add to the graph. Alternatively, you can add more elements to the graph by dragging the desired element icons.
The Rows, Graph, Customize, and Edit menus. For descriptions of these options, see the
Using JMP
book.
Help created on 9/19/2017
