Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Essential Graphing
Graph Builder
• Right-Click Menus
Right-Click Menus
Depending on where you right-click, Graph Builder gives you different menu options.
If you have multiple graphs (created with grouping zones or the Wrap zone), then right-click options apply as follows:
Any options that you apply to a graph element apply to all graphs, across all grouping and wrap variables.
To apply an option to only one graph, right-click in that graph area and select the option from the Graph menu.
To apply an option to all of your multiple graphs simultaneously, first hold down the Ctrl key and right-click, then select the option from the Graph menu.
Help created on 9/19/2017
