Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
The Fit Two Level Screening Platform
The Screening Report
• Half Normal Plot
Half Normal Plot
The Half Normal Plot shows the absolute value of the contrasts plotted against the absolute value of quantiles for the half-normal distribution. Significant effects appear separated from the line towards the upper right of the graph.
The Half Normal Plot is interactive. Select different model effects by dragging a rectangle around the effects of interest, or hold down CTRL and click on an effect name in the report.
Help created on 9/19/2017
